Hello Jeremy, hello guys!
At first please excuse my English. Hopefully you understand my questions.
I want to revalve my shock. I ride a ’97 YZ 125 and I have not the money to go to a tuner besides it’s really interesting. My Dealer should only fill my shock with new oil and nitrogen…
My shock feels too hard over small bumps. The rebound is fast enough but I think the Low-Speed-Compression is too much (compression adjuster all way out). So my shock don’t move trough acceleration bumps and so I lost very much traction. The rear end hops or bounce over these little bumps. On the other hand my shock feels to soft on fast rough sections with square edge bumps. There are so many big shims under the valve that I guess no oil can flow through it at low shaft speeds!?!
And I have no possibility to compare my valving with others, so I hope someone can help me with tips or a list of his own compression stack. (apart from linkage ratios, shock range of motion, used valve or piston …)
Much thanks ahead.
Compression Stack:
5x 0.15mm 40x12, (number, thickness, outer diameter in mm, inner diameter in mm)
7x 0.20mm 40x12,
1x 0.10mm 32x12,
1x 0.10mm 26x12,
1x 0.25mm 38x12,
1x 0.25mm 36x12,
1x 0.25mm 34x12,
1x 0.25mm 32x12,
1x 0.25mm 30x12,
1x 0.25mm 28x12,
1x 0.25mm 26x12,
1x 0.25mm 25x12,
1x 0.25mm 24x12
Much thanks ahead.
Compression Stack:
7x 0.20mm 40x12,
1x 0.10mm 32x12,
1x 0.10mm 26x12,
1x 0.25mm 38x12,
1x 0.25mm 36x12,
1x 0.25mm 34x12,
1x 0.25mm 32x12,
1x 0.25mm 30x12,
1x 0.25mm 28x12,
1x 0.25mm 26x12,
1x 0.25mm 25x12,
1x 0.25mm 24x12
