Does anyone know if headlight and rear fender from a 00 520 exc will fit a 99 380 mxc? I would be buying from out of state so a test fit would not be possible. Thanks!
Yes it will. The rear fender is a two part rear fender on the exc.. The exc, has the taillight portion that fits under the normal rear fender. The exc rear fender (non taillight portion) is made so the lighted portion fits into it. It is not the same as the mxc. You will have to use a couple of flat head machine screws, and wide (ID) washers to hold the tail light portion onto your mxc fender, and look decent.
Strick, thanks for the reply. Yeah, i know what you mean about the two piece rear fender. Looks like i wont have to worry about finding camp after dark anymore!
