Home
Basic Dirt Bike How-To's - Video
Living The Moto Life - Video
Bike Tests | Shoot-Outs - Video
Forums
What's new
Latest activity
Log-In
Join
What's new
Menu
Log-In
Join
Navigation
Install the app
Install
More options
Close Menu
Forums
MX, SX & Off-Road Discussions
Dirt Bike Mods & Maintenance
moisture in the flywheel side of the bike
Reply to thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Message
[QUOTE="SULLY, post: 792762, member: 30208"] Riding through water will draw in water to the LH casing. The engine is hot, when suddenly cooled by the water it creates a vacuum and draws in water. It's almost an impossible battle to overcome this, but besides regular cleaning and WD40'ing in there, I have had most success by... Put in the standard gasket, but coat it both sides with a fine bead of silicone sealant. put the casing on trying to not dislodge the bead of sealant. then do up the screws but only nip them up. Leave overnignt for the sealant to cure, then do up the screws fully to compress on the home made o ring you just made. [/QUOTE]
Verification
Which ocean is California closest to?
Post reply
Forums
Accept
Learn more…
Top
Bottom
