Here is the historic of my forks valving steps
(kx 250 01 try to make it woods bike.. springs are ok for 175lbs)
1- modified the Basevalve
Was
24x0.1 (X10)
22x0.1
20x0.1
18x0.1
16x0.1
14x0.1
11x0.2
18x? (X2)
Went for 24x0.1 (x3) this is the only change i have done to the BV, helped a little bit but not to much....Still too stiff
2- Changed the midvalve to a check
it really did the trick and the forks finally came alive. Now soak up well ruts and rocks.
Now i've been riding this setup for couple of days and feel like i have to fine tune on the base valve. The forks work great but i still have to much feedback. (it's weird though, i feel like the first stroke is soft and soak up every thing but the other half still give my some bad feedback) and i can't use the last 1 inch of stroke at all. And now am not really sure what to do. It happens when i go fast on rocky stuff when am stand up on the bike but when i ride on tight rocky trails at medium and slow bike speed and lower my body weight, it really work well... At this point it's hard to determine if it is LSC or HSC to play with. i tried different oil level for sure went from 100mm to 120mm but didn't notice much. i use 5wt maybe another weight would help too?
I may try just pull off the 16x0.1 shim ? which would softer the whole stack.
Was
24x0.1 (X10)
22x0.1
20x0.1
18x0.1
16x0.1
14x0.1
11x0.2
18x? (X2)
