my problem, 2002 yz250f, the lower piston wont extend when i remove the caliper and pump it out using the lever. i also have very limited stopping power. ive back bled the brakes and tried bleeding them quiet a few times so i figured the piston is my problem.
so i figured i should try to disassemble and clean the caliper. the service manual says i should replace oil and dust seals. i live in a small town and getting my hands on parts is a pain in the butt. can i get away with cleaning these and not replacing them?
when i drain the system with the pistons slide out with a little tugging? thanks
