-i rebuilt the top end on this 91 -rm125 and its the strangest thing, i can hit powerband but after that it just cuts in and out, then i can shift into the next gear and it does the same thing.
-i've completely torn the carbs down and cleaned everything,
replaced the reeds and still the same problem.
- i once read some info on Eric Gorr's website that talked about the linkage on the exhaust power valve having to be right, but i have the linkage connected, just not sure what to look for, when i use the kick starter to rotate the engine i dont see the valve moving or anything (i've removed the head) althought its quite hard to see as the piston is moving up and down past the valve.
-anyone have any ideas as to why this thing is cutting out ?
-could it be electrical, like a bad coil maybe ?
thanks all :bang:
thanks all :bang:
