look on the sidewall of the tire...if it's directional then it will have an arrow pointing in the way that the tire should spin. or just look at the knobies, then spin the tire around. if they look the same then it doesnt matter which way the tire spins
Hey,
I'm not sure on the 756. Most tires are directional, but I see that many people reverse their tires after the front edge gets rounded off. In other words, I don't think it really matters. Good luck.
The tread pattern looks the same both ways, except were the knobs taper. The only arrows that are on the tire are is the dunlop logo (an arrow with a D in it). The Bridgestones that were on it were directional. Do you ever wish you would have paid somebody do it for you. I just can't afford it. As long as I don't pinch the tube I will be alright.
