I bought an XR107 which i recently put a new motor in.. im just looking for the most performance i can get, when i bought my new motor i dissassembled the top end and put in a higher compression piston and rings,Which helped alot, but isnt enough. I got FMF exhuast and 22MM Carb. i imagine its getting around 14-17 HP to the crank and maybee 9-11 to the wheel, which isnt enough for me. Is there anything else i can do? Im pretty new to the whole pitbikes thing.. Is there like mini turbo kits? the biggest motor i could find was this 125. thanks for the help.
* by the way i think my bike is running too rich.. i put my hand in front of the exhuast and revved it up, and i could feel wet gas through my glove, it also backfires alot when im going downhill or letting off the gas. is the an air mixture screw or something i can adjust? the backfiring is very annoying and its a firehazard to my property. theres a screw on the bottom of the carb, closest to the intake port, that i think is the air mixture screw.. i just dont know if i have to back it off or run it in or how much.
