rfd499
27
I have a chance to get a flywheel weight off a older CR 250 and need to know what size is on the '01 CR 250. The person selling knows the flywheel size on his 250 and I need to make sure that they are the same. Thanks!
bikepilot
804
A flywheel weight is a bolt on accessory, generally it doesn't replace the stock flywheel. The bolt-on weights (like steahly) from 1990-2001 CR250R's are the same, so if its from a bike in that range you should be good to go.
