abuckley1290
- Jul 29, 2005
- 2
- 0
Hi i have a 2001 rm125. When i give it wide open throttle at low rpms, it bogs down. It runs perfectly everywhere else. How can i fix this?
Hey! I think that I may have grenaded the top end of my 125 2 stroke while riding midrange in 3rd gear. How hard is this to fix and how expensive, what may I have done wrong to cause it to blow other than running to lean in midrange? It completely sputtered, bogged down, and stalled when it happened and won't crank. its a 2005 and I havent had it for long. ( i got it not long after I turned 13 and just turned 14 a few weeks ago)How do you go wide open at low rpm? Interesting. Low end bog could be an air leak at the reed block, clean that unit and add new reeds, Boyseen of course! If that don't work, go one leaner on the pilot jet, and raise the needle clip one notch up fer lean. Clean and or replace air filter. Good luck, The Red Rider! View attachment 20569
Sometimes one can find a used crank shaft on ebay or at a cycle salvage yard, and I think they warentee them. Just check for slack in the connecting rod bearings, a little side to side is acceptable, but there should be on radial play. Try ebay, I found lots of goodies for my ancient CR's, you should be ok too, good luck!sooo.... I got the top end removed and the boar is fine as well as the piston looks like its in perfect shape, so it looks like its the crankshaft, which really pisses me off cause there's an aftermarket hot rod shaft in it thats not that old so looks like im looking at a lot more work on the crank than I wanted to do.
