I’m doing my first top on my 02 CR 250 and have two questions. The first I think is obvious but want to clarify where the owners manual is vague.
For the RC value the manual says to remove the socket bolt and stopper plate. Then remove the valve shaft assembly and flap valves from the cylinder. This is done after removing the cylinder from the cases, correct?
Is there clearance to remove the cylinder with the head on?
Thanks,
Sawblade
Thanks,
Sawblade
