Demon Speed
- Apr 26, 2003
- 5
- 0
I just bought an 02' CR250. I noticed that it wouldn't clear out and seemed to be running rich. It sounds like the silencer is stopped up if you know what I mean, doesn't have the a bark that a strong running 250 normally has. Taking a plug reading indicated this also. It has an FMF pipe/silencer but is otherwise stock.
Runnning 32:1 Maxima 927 on 93 octane fuel.
I found the bike had a 400 main jet, needle second position, and pilot 32.5. FMF recommends a 380 main and needle in 3rd position. I moved the needle to the 3rd and tried a 390 jet first, with no real improvement. Then tried a 380, with no improvement. Also pulled the plug after going with this jetting and the plug looked quite oily on the threads and dark brown on the porcelan below the electrode.
Finally I tried moving the needle to the second position which obviously made the bike run lean, ( would start surging and ping when throttle was applied.)
The power valve appears to be working, not sure if adjusted correctly though. I took the cover off and reved it a few times to see if the leave arm moved, which it did.
I haven't had time to look at it again this week, but a compression check is next.
Probably will pull the exhaust off too to look for any obstructions and have a closer look at the power vavle.
Does anyone have any other suggestions?
