dirtbikr99
- Nov 21, 2002
- 180
- 0
Hi, I picked up a 2002 ktm 125 as a project. Buy and sell. Got it for 350 bucks. Had a bad top end.
Tore into it, needed full rebuild bottom and top. I put new main bearings and seals and rebuild the crank. Top end has 2mm over bore, sleeve. There was no chamfering on the ports haha. I chamfered the ports, honed it and did a little porting to the exhuast. Put new wiesco 56 mm piston in it. Cleaned the carb. Cleaned the power valves and made sure the timing marks were correct.
Starts up good. Does not rev out fully.
I am careless and did not check too see the main for pilot jet sizes. I am thinking its not getting enough fuel.
What do you guys think? What would be good jets for this bike?
Thanks a ton.
Thanks a ton.
