Jacob Hansen
- Nov 15, 2004
- 15
- 0
Hey.
I just bought a `03 Honda CR250. I discovered that it has a strange "knocking" sound. sounds like a piston rattle, or really bad timing/detonation. But the piston is only 4 hours old, so it shouldn't be the piston.. right?? The "knocking" sound is loudest at idle, if it was bad timing/detonation it would be loudest at hard pull.... right?? so my question is.... what the H... is it.. The bottom shouldn't make that kind of noise after only a year should it. The problem doesn't go away with the clutch engaged/disengaged. It also feels like it running lean in the top end, is there a connection with my "knocking" problem..
PLEASE HELP! :ugg:
Best regards Jacob Hansen
Denmark
PLEASE HELP! :ugg:
Denmark
