Jeremy Wilkey
Owner, MX-Tech
- Jan 28, 2000
- 1,453
- 0
Stock Valve Settings Fork
Bike:04CRF250 Stock settings
Showa 47 12/23/33 cartridge
Black Clicker Face
Oil:379cc
Rebound: Valve: 23mm, 4port, 1,3mm bleed (on active side)Spring: 43-495-.45 Marked by 1 Line
Passive:
63010 x 16
29.1
28.1
27.1
26.1
25.1
24.1
23.1
22.1
21.1
20.1
19.1
30.5 x 2mm
2.2 ICS
16.1 x 10
15.1
14.1
13.1
12.1
11.2
16.3
Active:
08x 20.1x4
17.1 x 4
9.5 x .2 x 1
10.2 x 2
2mm Post
Float .2mm
Rebound:
06x 20.1x2
18.1
12.1
16.1
14.1
13.1
12.1
11.2
16.3 x 3
Stock Valve Settings Shock
Bike: CRF250
Shock: Showa 50/16
E to E L: 486.9
S TRVL:
Oil: 150 psi
Gas:
Comp:
H:
L:
Rebound:
Sag:
Spring: 5.3 kg/mm
Preload: 10mm
Piston: 50mm (no bleed)
Comp:
44.2x7
44.15 x6
37.15
30.15
42.2 x 2
42.25
40.3
38.3
36.3
34.3
32.3
30.3
28.3
27.3
26.3
25.3
24.3
23.2
22.3
21.3
Rebound:
40.2x1
24.1
40.3
38.3
36.3
34.3
32.3
30.3
29.3
28.3
27.3
26.3
Black Clicker Face
Oil:379cc
Passive:
63010 x 16
29.1
28.1
27.1
26.1
25.1
24.1
23.1
22.1
21.1
20.1
19.1
30.5 x 2mm
2.2 ICS
16.1 x 10
15.1
14.1
13.1
12.1
11.2
16.3
Active:
08x 20.1x4
17.1 x 4
9.5 x .2 x 1
10.2 x 2
2mm Post
Float .2mm
Rebound:
06x 20.1x2
18.1
12.1
16.1
14.1
13.1
12.1
11.2
16.3 x 3
Bike: CRF250
Shock: Showa 50/16
E to E L: 486.9
S TRVL:
Oil: 150 psi
Gas:
Comp:
H:
L:
Rebound:
Sag:
Spring: 5.3 kg/mm
Preload: 10mm
Comp:
44.2x7
44.15 x6
37.15
30.15
42.2 x 2
42.25
40.3
38.3
36.3
34.3
32.3
30.3
28.3
27.3
26.3
25.3
24.3
23.2
22.3
21.3
Rebound:
40.2x1
24.1
40.3
38.3
36.3
34.3
32.3
30.3
29.3
28.3
27.3
26.3
