Jeremy Wilkey
Owner, MX-Tech
- Jan 28, 2000
- 1,453
- 0
Stock Valve Settings Fork
Bike:04CRF250X Stock settings
Showa 47 12/23/33 cartridge
Oil: 390CC
Comp:
Rebound: Valve: 23mm, 4port, 1,3mm bleed (on active side)
Spring: 43-495-.42 Marked by 2 Parrell Lines
Passive:
63010 x 14
27.1
29.1 x 2
28.1 x 2
27.1
26.1
25.1
24.1
23.1
22.1
21.1
20.1
18.1
16.1
14.2 x 5
Active:
08x 20.1x3
17.1 x 4
10.2 x 3
2mm Post
Float .2mm
Rebound:
06x 20.1x1
19.1
18.1
12.1
16.1
14.1
13.1
12.1
11.2
16.3 x 4
Notes:
No passive bleed shims
Black Clicker Face (Tag)
1.7 ICS
1.1045 Oil Lock Piston (small)
Stock Valve Settings Shock
Bike: CRF250X
Shock: Showa 50/16
E to E L: 468.9
S TRVL: 118mm
Oil:
Gas: 150 psi
Comp:
H:
L:
Rebound:
Sag:
Spring: 4.8/50
Preload: 10mm
Piston: 50mm (no bleed)
Comp:
44.2x16
44.15
38.15
30.15
44.25
42.25
40.3
38.3
36.3
34.3
32.3
30.3
28.3
27.3
26.3
25.3
24.3
23.2
22.3
21.3
Rebound:
40.2x3
24.1
40.25
38.25
36.3
34.3
32.3
30.3
29.3
28.3
Notes:
Seal head is old style with no top out spring..
Oil: 390CC
Comp:
Passive:
63010 x 14
27.1
29.1 x 2
28.1 x 2
27.1
26.1
25.1
24.1
23.1
22.1
21.1
20.1
18.1
16.1
14.2 x 5
Active:
08x 20.1x3
17.1 x 4
10.2 x 3
2mm Post
Float .2mm
Rebound:
06x 20.1x1
19.1
18.1
12.1
16.1
14.1
13.1
12.1
11.2
16.3 x 4
Notes:
1.7 ICS
Bike: CRF250X
Shock: Showa 50/16
E to E L: 468.9
S TRVL: 118mm
Oil:
Gas: 150 psi
Comp:
H:
L:
Rebound:
Sag:
Spring: 4.8/50
Preload: 10mm
Comp:
44.2x16
44.15
38.15
30.15
44.25
42.25
40.3
38.3
36.3
34.3
32.3
30.3
28.3
27.3
26.3
25.3
24.3
23.2
22.3
21.3
Rebound:
40.2x3
24.1
40.25
38.25
36.3
34.3
32.3
30.3
29.3
28.3
Notes:
