Jeremy Wilkey
Owner, MX-Tech
- Jan 28, 2000
- 1,453
- 0
KTM 450/525 SX Racing '04
Needle: d8.2 / d10.2 L=57mm
Spacer: 2.5mm under bump rubber
Comp. LS: 12 open
Rebound: 22 open
Needle: d10 L57
O/A Length: 403mm
Comp HS: 2t open
Spring: 88-250
Spring P/L: 5mm
N2 Pressure: 10 BAR
Rebound bush:
Stroke: 111mm
Bleed: 1.0mm
PISTON 1
Compression
16x22x0.30
16x30x0.25
16x32x0.25
16x34x0.25
16x36x0.20
16x38x0.20
16x40x0.20
16x42x0.20
16x34x0.15
6 - 16x44x0.20
Rebound
16x20x0.30
16x28x0.20
16x32x0.20
16x34x0.20
16x28x0.15
2 - 16x36x0.25
PISTON 2
Compression
16x21x0.30
16x30x0.25
16x32x0.25
16x34x0.25
16x36x0.20
16x38x0.20
16x40x0.20
16x42x0.20
16x44x0.20
Rebound
16x28x0.30
21x36x0.25
16x21x1.0
CC Mech
Piston 5018.0353.
6x22x0.25
6x20x0.25
6x18x0.25
6x16x0.25
6x14x0.25
6x9.5x0.30
Type: KTM 450/525 SX '04
Remarks: d48
Comp.: 18 out
Pre-load: 5 mm
Total length: 940mm
Oil: 4860.0211.
Rebound: 19 out
Spring: C=4.6kg
Stroke: 300mm
Air Chamber: 100mm
Spring with spacer = 513mm
Compression
6x18x0.25
6x10x0.25
6x11x0.10
6x12x0.10
6x13x0.10
6x14x0.10
6x15x0.10
6x16x0.10
6x17x0.10
6x18x0.10
6x19x0.10
6x20x0.10
6x22x0.10
4 - 6x24x0.10
Check Valve
Spring: 4860.0202.
Shim d8xd24x0.4
LH = 1.5mm
Piston: 4860.0047.
Rebound
6x16x0.25
2 - 6x9.5x0.30
6x14x0.10
6x16x0.10
6x18x0.10
6x20x0.10
6x16x0.10
4 - D:6x24x0.10
Mid Valve
8x11x0.20
8x16x0.15
8x11x0.40
2 - 8x12x0.10
8x16x0.10
8x20x0.10
3 - 8x24x0.10
LH = 0.9mm
Spring: 3548.0377.
Piston: 4860.0042.
Comp. LS: 12 open
Rebound: 22 open
Needle: d10 L57
O/A Length: 403mm
Comp HS: 2t open
Spring: 88-250
Spring P/L: 5mm
N2 Pressure: 10 BAR
Rebound bush:
Stroke: 111mm
Bleed: 1.0mm
PISTON 1
Compression
16x22x0.30
16x30x0.25
16x32x0.25
16x34x0.25
16x36x0.20
16x38x0.20
16x40x0.20
16x42x0.20
16x34x0.15
6 - 16x44x0.20
Rebound
16x20x0.30
16x28x0.20
16x32x0.20
16x34x0.20
16x28x0.15
2 - 16x36x0.25
PISTON 2
Compression
16x21x0.30
16x30x0.25
16x32x0.25
16x34x0.25
16x36x0.20
16x38x0.20
16x40x0.20
16x42x0.20
16x44x0.20
Rebound
16x28x0.30
21x36x0.25
16x21x1.0
CC Mech
Piston 5018.0353.
6x22x0.25
6x20x0.25
6x18x0.25
6x16x0.25
6x14x0.25
6x9.5x0.30
Remarks: d48
Comp.: 18 out
Pre-load: 5 mm
Total length: 940mm
Oil: 4860.0211.
Rebound: 19 out
Spring: C=4.6kg
Stroke: 300mm
Air Chamber: 100mm
Compression
6x18x0.25
6x10x0.25
6x11x0.10
6x12x0.10
6x13x0.10
6x14x0.10
6x15x0.10
6x16x0.10
6x17x0.10
6x18x0.10
6x19x0.10
6x20x0.10
6x22x0.10
4 - 6x24x0.10
Check Valve
Spring: 4860.0202.
Shim d8xd24x0.4
LH = 1.5mm
Piston: 4860.0047.
Rebound
6x16x0.25
2 - 6x9.5x0.30
6x14x0.10
6x16x0.10
6x18x0.10
6x20x0.10
6x16x0.10
4 - D:6x24x0.10
Mid Valve
8x11x0.20
8x16x0.15
8x11x0.40
2 - 8x12x0.10
8x16x0.10
8x20x0.10
3 - 8x24x0.10
LH = 0.9mm
Spring: 3548.0377.
Piston: 4860.0042.
