Jeremy Wilkey
Owner, MX-Tech
Jan 28, 2000
1,453
Stock Valve Settings Shock
Bike: RM250 04
Shock: Showa 50/16
Oil:
Gas: 130 psi
Comp:
H: 2
L: 6
Rebound: 10
Sag:
Spring: 4.6/50
Preload: 10mm
Piston: 50mm (no bleed)
Comp:
44.2x8
38.15
30.15
42.2
40.2
38.25
36.25
34.25
32.25
30.25
28.25
26.3
24.3
23.3
22.3
Washer 30.3
Rebound:
40.2x2
40.25
23.1
40.25x5
32.1
40.3
38.3
36.3
34.3
32.3
30.3
29.3
28.3
27.3
26.3
25.3x2
Washer 25,75mm x 3mm
Stock Valve Settings Fork
Bike:04RM250 Stock settings
Showa 47 12/23 cartridge
Oil:
Comp: Valve: 23mm, 3port, no-bleed
Rebound: Valve: 23mm, 4port, 1,3mm bleed (on active side)
Spring: 43-495-.43
Passive:
06x 20.1x3
8.1
20.1
19.1
18.1
17.1
16.1
15.1
14.1
13.1
12.1
11.1
10.1
9.1
8,5 .2
11,5 .3 x6 washer
No passive bleed shims
Active:
08x 20.1x8
7,9x2mm spacer
9,5 .3 x2 washer
11.3 washer
Float 0,1 - 0,15mm
Rebound:
06x 20.1x2
18.1
12.1
17.1
16.1
14.1
13.1
12.1
11.1
10.2
12.2x2 washer
FRESH VIDEO
