1/8-1/4" Carbon in Exhaust Pipe.
mlhend1
186
I recently changed from the stock pipe to a FMF Fatty pipe. Upon removing the stock pipe I noticed about a quarter of an inch of solid carbon inside of the pipe, at least where it meets up with the engine. I bought the 1994 KDX 200 with 500 miles on the odometer last year. It was about a half year before I changed the jetting and plug (to br8eg) to get it from running so rich. I also switched to Mobile 1 Sythnetic 2 cycle oil 40:1. What causes the carbon and what can I do to help eliminate carbon deposits in my new FMF pipe? Thanks!!!
mlhend1
186
Someone suggested removing the pipe, plugging one end filling it with water, plug the other end and let sit for a few days. Scrub with a steel brush. Is there a better way?
CaptainObvious
Formally known as RV6Junkie
3,331
If you jetting is correct you will get very little of those carbon deposits. Before I modified my bike (including proper jetting) my stock pike was choked with carbon. My modified bike has always had a clean pipe.
Carb cleaner or oven cleaner works OK on carbon.
