Bike has been sitting since July. Haven't started it or even moved it. (been riding other bike) Went to mess with it today. It started about half-way through second kick just fine. Went to shift into 1st gear and the clutch was not working. Put it in neutral, started on first kick as it usually does. Turned it off, put it in gear and rocked it back and forth a little. Clutch does not seem to be working at all. I checked to see if the cable was moving the arm on the outside of the case and it is working as usual. Could it just need to be ran out in the field or wherever to get the clutch working again. Could it not be working just from sitting for too long? Book doesn't say anything about it. Thanks.
