1982 CR 125 Shock Seals
ski5503
15
Anyone know where to get rear shock seals for a 1982 Honda CR125. I checked ebay,no luck... Thanks.
Service Honda or a vintage race shop for a seal? I believe I have a few 82 CR480 shocks with the same issue! They are a little shorter than the 83. Fleabay is a last ditch shot in the dark for parts. Vintage Bob
Pete Payne
MX-Tech Suspension Agent
Nov 3, 2000
933
38
Thats a Showa , 40 mm shock body , 14mm shock shaft.
MX-Tech should have them !
Ask for
ssos14 (oil seal )
ssds14 (dust seal)
sm7482
224
I re-built some 70's showa 360 shocks that came off of an mr250 for my mt250 using some regular seals from a bearing shop. i put them together and pumped them up and down for quite some time without a little residue of oil showing on the shafts but as for long time wear i'm unsure as i havn't mounted them yet. i used old mountain bike boots to cover the inside so no dirt will get to the seals. they match my fork boots now!
<a href="http://photobucket.com" target="_blank"><img src="http://i116.photobucket.com/albums/o3/rock_krawler/DSCF1423.jpg" border="0" alt="Photobucket"></a>
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
