i have one and it starts good and runs ok but pops or breaks up at high rpms. it still pulls a little but not as much as it should. it has a pc pipe and scilencer but does not have the stock air box(it definitly gets better airflow) and not the stock subframe. :uh:
the left side crankseal was replaced but still seemed to leak a little. it still; broke up with the new seal just the same as before. i can replace it again the job was cake but ive read that you pack the area the crank seal goes into with thick grese (to help make a seal)but i dont know. i tryed jetting it on i went from a 165 main from a 178 with no help all the way to a 220. that seemed to not have any effect on it. when jetting it the pin that holds the float in place wanted to fall out when i tilted the carb. i just pushed it back in and went. im pretty sure the powervalves are working so i dont thing that is it. i checkd for an airleak(spraying soapy water around all the visible gakets) but none showed up. the top end couldnt have 15 hours on and no blow by is visible on the piston and it had 190psi on the complession test. the powervalves are not seaced. the plug never seemed rich or lean. it holds all the radiator fluid so i know that dosnt have much or anything to do w/ it. i have a service manual but it didnt help very much. some1 please help. it also has boyesen reeds
