1999 rm250
rippenkawi
16
just bought this bike today and im going through it making sure everything is ok but my question is about how much tranny oil does the bike take and what is the best fuel ratio to run it at, and if anybody has any other tips for the bike. thanks
whitesands26
Mod Ban
Nov 17, 2002
220
Did the bike come with a manual ? In case you didn't think about it you might want to ask if they have a manual to go with it so you'll know how much tranny oil to put in it.
As for the fuel/oil ratio, 32:1 would be ideal for a 250cc motocross bike and most manuals suggest this ratio as well...Some guys run 40:1 but to be on the safe side I'd go with 32:1.
The pre mix oil of choice from many of the experts on these forums seems to be the FULLY synthetic Mobil MX2T that you can get at autozone for a pretty good price when compared to the stuff the motorcycle shops sell..It's about $3.50. I use it and it is a very clean oil that helps eliminate some of the leftover spooge that's common with two stroke motocross bikes...The only thing is that the oil has no color in it so you need to always make sure you have oil in it because you won't be able to tell by looking at the color of the gasoline. Other than that it's an excellent high performance two stroke oil.
RM_guy
Moderator
7,058
214
North East USA
The oil capacity should be cast into the clutch side cover near the oil fill plug. It is probably 700 to 750 ml. It's better to error on the side of too much oil if your not sure. The excess will just blow out the vent.
Erick82
443
My 02 is 750ml for the tranny and i use use Mobil red cap 50w-15, I run Mobil MX2T @ 32:1 for mix.
Mudboy
95
I have this very bike. Changing oil is as simple as it gets on this.
Go buy a case of AFT Type F and it holds exactly one quart. I've
done three top-ends on the bike and I'm just getting ready to change
the clutch. I've gone through two cases of the stuff and it works and
it's cheap and it's the correct amount.
Green Horn
aka Chip Carbone
2,563
...And even though there is plenty of people to help answer your questions I'd still buy a manual for the bike if you don't get one from the previous owner. It's always good to have it on hand when working on the bike. It'll save ya from having to run inside + log onto DRN + ask question + wait for response. :thumb:
2000FLSTF
32
Mudboy - what plug are you running?....and what pipe and jet setup do you have?
Mudboy
95
I'm running an FMF fatty pipe, an NGK BR8ES plug, and V-Force reeds. I don't remember the jetting but I'm at 5,000 feet and the riding areas go up from there so my jetting probably won't work for most...
This bike still pulls as hard as about anything, but I wouldn't call it a smooth power. You rev it like a 125 and keep it on the pipe, which is fine for me since I only ride the dunes with it.
kev_rm
195
it's about 8/10 of a quart - I just sold this same bike and I had terrible clutch dragging with ATF and EBC clutch, so I switched back to motor oil. I also had zero luck jetting it for slow speed woods, so I ended up running a 7 plug for woods and 8 for dunes. It never fouled, but it always spooged heavily in the woods. Porting for low end would probably help the whole situation, but I gave up and bought a thumper :P
rippenkawi
16
Dealer told me my bike had to have a special 30 dollar spark plug is this true or I really dont need to run it?
kev_rm
195
Towards the end, I gave up on those and just changed it frequently. the 30$ plug is supposedly to help a problem with the motors generating a vibration that causes the electrode tip to fall off (you can see the difference in construction if you compare them). I didn't have any problems with the BR8 and the BR7.
