So i got a crack in my clutch cover/crankcase cover then about a week or so later it died while ridin and now wont start the crankcase did ooze out alot of oil what is the problem?
That oil that oozed out, used to lube your transmission. The top end may be good? A manual would have been cheap, as to the cost of another engine? Vintage Bob
I had the same thing happen to me. Check your idler gear and see if the bolt is tight. And replace the clutch side case usually called (case 1) in manuals. You could have burned your tranny out =/
