2 base gaskets will lower the compression and change the port timimg.Originally posted by MikeT
Your cylinder base might be warped. You might just want to use two base gaskets and some Yamabond. That should seal it.
I know, but it's better than running lean and potentially blowing his crank... :DOriginally posted by RM_guy
