razorboy
186
Hi Fellas,
I am dealing with a small problem with my revived PW80. I need to know if the float bowl overflow and the float bowl drain share the same orifice? As I try to start the bike, there is fuel draining from the tube on the side of the carb. What does this indicate ---- stuck float?
Another simple one for those of us without manuals...
What is the correct sparkplug gap?
TIA
Bernie
FruDaddy
2,854
Check the float height, it should be.82-.90 in (20.8-22.8mm)
Fill the bowl with gas and see if the float sinks.
Take a good look at the needle valve, that could also be the culprit.
Pull the drain screw out completely, if its tip is damaged, it may not be sealing properly.
I am not sure which orifice is used for the overflow and which for the drain.
Plug should be NGK BP6HS or equiv, gap @ .024-.028 in (.6-.7mm)
razorboy
186
Thanx mate,
Much appreciated. I think I am having some issues with that little carb so its coming off tonight.....
Cheers
Bernie
