I have a 00' KX 250 I need help with. It has a PC pipe on it, everything else stock. The guy who rides it is really slow, and it is spooging everywhere. He rarely gets past 3 gear and rolls most jumps.
What specs do you think I should try out? I'm tired of cleaning out his fouled plugs!
Sounds to me like he rides at about 1/4 throttle everywhere, which means the pilot jet is being used the most. Throw a leaner pilot in there and see where that gets ya.
Another thing you might try is an N3WF needle at the same clip position. The stock needle is N3WE. The "F" needle has a slightly larger straight-part, affecting jetting at 1/4 throttle.
It most likely rich everywhere. If he is riding slow then I would think it is running rich in the pilot, needle, and most likely the main jet also. First try leaning out the pilot jet and raising the clip on the needle or try the leaner KX needle. While your gonna be doing that a I would do a plug check on the main jet and see if it needs a leaner main jet while you have the carb apart.
You should go down 1-2 sizes at a time on both the pilot or main. You might end up buying a few jets but they are a good investment when the temperature changes outside and your jetting needs to be adjusted. Most riders ask me "Why the heck do you spend all that money on jets?" And I simply tell them "well for one I'd rather have my jetting dialed in then have fouling plugs and spooge like you do, so my investment in jets is like 2 things in 1, maintance & performance."
Sounds like an interesting concept, but if I am refering to a PC P I P E, linking it to F M F just doesn't make sense. Most can see the Sponsorlinks to the left, and as case and point, I used it to get my 400's motor big bored just last week so they doo work and asa direct result of this board, Eric got $500 of my cash.
2.50 for jets!!?? The dealer charged me EIGHT BUCKS A PIECE!! The same dealer that tried to charge me $116 for a Renthal O-ring! Can you seriously get jets for $2.50? mumble..mumble..mumble....grrrr...mumble...
