2001 KX250 throttle position sensor returnspring failure?.
Hi!
Yesterday when I was out riding something strange occured to my bike.
I was riding at a beach, and was also riding a little in the water, sometimes the water "splashed" all over the bike, however I don`t know if this is related to the problem.
Anyway, I was about to pop a wheelie, I came almost to a dead stop and then suddenly the bike stopped, just as if I hit the stop button. I thought the sparkplug fouled, so I went home and picked up a new plug, threw it in the cyl and tried to crank her up. No difference.
When I looked at the old sparkplug it had a nice tan, chocolate color, so it wasn`t the plug after all.
I then thought that maybe water had made it`s way into the carb, so I laid the bike down on it`s side to drain the float chamber.
Then I tried cranking it up again, and it started.
However, when I tried to rew it , it started burbling, but it cleared up after a little while, so I thought it was water in my carb.
I also noticed that the throttle handle - operation was wierd. When I gave it throttle I suddenly felt a "stop" in the movement of the throttle, it didn`t require much force to get over the "stop" but I felt that something was wrong.
I rode the bike home at low rpm and today I remove the carb.
Took the carb off today and I found out what was causing the wierd throttle feel/operation.
It seems like the TPS arm has came "further" out and the return spring-tap is hitting the carb wall when giving much throttle.
Here are some pictures:
Here you can see were the spring tap will hit:
I was able to push it back to normal postion with my finger:
But it came out again just as easy.
I checked the parts diagram and it seems like the part is a single unit with no removable parts or anything.
What could have happened?.
Could it have something to do with the burbling?.
When I rode the bike home it seemed to rew as normal, with no burbling, but the throttle operation wasn`t smooth, suddenly I felt the "stop" in the rotation of the throttle, but I think the powerjet still worked?.
Gees I wanna go riding !!!
Oh here`s a little wheelie pic.
Joakim.
Hi!
Joakim.
