2002 KX 65 Running Rich - Help !
CR500R
13
2002 KX65 in Colorado- 5000 feet elevation
I have a new 2002 KX 65. I dropped the main from stk 190 to 180.
Dropped the pilot from stk 25 to 22.5, raised the neelde clip up a notch to lean it out and it is STILL Rich.
I am running a B9ES plug (one range hotterthan B10 stock)
The plug insulator is shinny and dark but not dripping wet or oil fouled.
There is a little spooge from the tail pipe (just repacked)....
It sounds like I'm close here....should I go to a hotter plug?
Raise Clip to top?
Any Ideas here??
Thanks,
John
MXP1MP
1,845
I would try raising the needle to the top clip see if that doesn't help you might want to go to a leaner needle if it doesn't work then.
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
