2002 RM125 powerband flat spot
robwbright
2,283
Hi guys:
I posted a simliar question a couple weeks ago and got no response.
My recently purchased 02 rm125 has a Bill's Pipe and silencer.
There is a strange "flat spot" in the upper mid range where it feels as if the bike has peaked. Maybe about 2/3 throttle. The flat sport lasts maybe 1000-2000rpm. Then if you gas it, the bike takes off hard.
Having ridden on and off for 25 years, this does not feel like a "normal" powerband to me.
Any ideas? Could it be the Bills Pipe?
Rob
nickyd
873
sounds like a 125 to me!!!!!! its missing the other 125 cc's!!
just kidding. 125's in my experience do have a dead "lull" in them - usually in lower end (or lack thereof). where do you feel this transition most? It could just be the powerband coming to life - or your p-valve could be coming to game late.
robwbright
2,283
It's upper mid (guessing) 8000-9000 rpm range. Maybe it's normal, but I've not ridden anything like it before. It's not really a problem as there is tons of power on top and the range above the flat spot is wide enough to "keep it on the pipe". It just seems a bit odd for a curve to rise slowly, hit, flatten and then hit again. . .
sick 96 250
1,207
have you messed with your main jet at all? Could be to lean or to rich causing it to fall flat once in the higher RPM's
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
