2002 yz125 or yz250f
marcv125
727
I have an 2000 yz125 which is now on sale bye the way:p but anyways im a little on the small size. 5'7' 144 to be exact. I love the nimbleness (if that is a word) and light weight of the 2 stroke but i heard the 4 stroke is just to good. Will i do the same on either bike or will i have an advantage on a certain one. I wil be racing nema (new england motocross association) and i want a bike that i will feel comfortable on all year. If anyone has either bike or rode either bike and can tell me their experiences i would greatly appreciate it. Thank u all :)
MXP1MP
1,845
I got an '02 YZ125 I love the damn thing it rocks its very similar to your 2000 as far as the motor go's. What will feel better is the newer body work, and the suspension will be better slightly. I like how my YZ handles after ridding mostly honda CR's the last few years. I wasn't expecting it to slice like the CR did but it does! The bike feels razor sharp but yet has great stability I guess its middle of the road but at the same time not. I think it gets more of the stability from the suspension since its pretty balanced stock. The bike is awesome with just some minor jetting tweaks and adding two teeth to the rear sprocket it will win right off the showroom floor. Compared to the YZF. Yes its an awesome bike but I feel it still has a few more years to go yet. You must ask yourself can you handle the starting ritual that comes with the bike its only bad when you dump the bike. My friend who races one dreads if that happens. That and the other thing is it will have smooth power band compared to a 2 smoke. It won't have that cut and thrust style to it. That and I understand it isn't that friendly of a bike to vertically challenged peeps like me and you. You can't go wrong with either bike really that right there has to be the main difference's in why you'd choose one over another. Other than the fact the YZ got the new bodywork thats it. Otherwise get the one you want, but don't blame me when your stuck on the side of the track getting a work out kickin that YZF :p hehe.
marcv125
727
Engine wise you say is comparable to my 2000. If i get the 2002, i would feel a difference right? And yes the dump and start thing i heard is very hard on the 4 stroke. Ye i do love the new body work on the yz125 though very nice. Thanks for all ur info though:)
MXP1MP
1,845
2002 motor us best described as being a cross between the 2000 torque and the 2001 over rev. not quite as much on bottom as the '00 had but close and not quite as much overrev the '01 had but very close. This power band is favored more due to the bottom being pumped up. I heard adding a pro circuit pipe /shorty silencer livens things up quite a bit. All three model years make the same HP figures 33 hp stock. The new bodywork is excellent, it was one of the reason's why I didn't get a YZ last year. I have had this bike since august and have ridden it 90% MX. I've currently racing it in the local AX series right now. One of the biggest questions I get asked is how do you like the 5 speed tranny. I don't notice it cause I had an '01 Cr125 before this bike. I usually ask them in return, how many times do you ever shift into 6th? usually followed by a long pause of pondering. If there was one thing I don't like about it, is sometimes 1st to 2nd up or down it get hung up on neutral but this only happens when you use the clutch and shift and its not consistant enough. Its not a problem if you shift under power or don't use the clutch and the bike is rolling. Depending on how agressive you ride might want to raise the oil in the forks it can bottom out on slapper landings but its far from harsh. like 10 -15 mms more of oil do it. So whatever bike you get I'm sure you'll love it, but I made the same choice you can see what I got :)
MxRyder187
10
major handling difference...
although i havent ridden a yzf (or a yz for that matter) i read in a moto mag that the 2 strokes at rear wheel drive, and the 4-strokes are front wheel drive
meaning when your turning, you use more throttle control to turn than on a 4 stroke. this can be an advantage but only in great conditions, like really hard pack turns. If its sandy or muddy, it may become difficult, and the 2-strokes have the advantage.
I was really considering a 2001 yz250f for my next bike, but after hearing this, im moving more twards a yz125. I would ride both on both hard and soft courses if possible, if not try and get buddy-buddy with someone on more of a sandy course so you could witness a 4-stroke at its worst. Thats what i plan to do when the time comes.
After hearing this, i consider a 2-stroke the better all-around bike. This is just my opinion though.
later,
mxryder
marcv125
727
thanks for the great write ups. I am leaning to the yz125 more just because of my weight, and i am used to the yz's weight. And i love the engine on the 00 but not the ergos. I love the new look of the bike and about the tranny..I heard if you add 2 teeth to the sprocket if fixed everything. Just what i heard though. And i read in the recent dirt bike mag. that the pc pipe w/ shorty silencer is the best combo. I think this and a rad valve would perform pretty well to a 250f with a pipe on it. Handeling wise i def think it will be a big difference. Again thx for the help and anything else about the yz125 that i should know about, would be gretly appreciated :)
marcv125
727
When you add 2 teeth to the rear. How much does it cost and what does it change it to? a 50 tooth rear?
