250 Yz 2003
bclapham
4,340
i can just hear my mother now....."youve only had that bloody bike 10 minutes and youv'e already taken it apart!"
Can wait to hear how the 03 handles dean, please let us know!
DEANSFASTWAY
1,192
03 no bleed hole . We had to make it stiffer but the rider is a larger sized mammal and hes a proexpert. On the forks it looks like we should make a new cap socket The fork caps have a real deep bult protrusion but one of the spars or flats should be cut out . Likr taking a good 6 pt socket and butting out one of the flats with a die grinder @10mms deep . That might keep from twisting the soft aluminum nut protrusion area. Looks like there is way lesscomp valving in the 250 forks and more spring . Actually they work pretty good stock but this guy was taxing the stock setup . Bike is real fast stock. Youll see . DEAN
Jeff Howe
456
Yamaha's have never had air bleeds in the sealheads, which is odd because Kawi KYB shocks have had them since 99 I believe.
marcusgunby
6,450
Ahh im confusing the KX seal heads with YZ ones-i have a old YZ one in my box i will look into it, one thing i cannot understand is the CR125 uses a really heavy steel seal head and yet Honda try to loose weight everywhere else-they could easily loose a lb on the seal head going to the ally type.
marcusgunby
6,450
Yes dean i adgree but if money is the reason why go to the alloy frame?seems strange the priorities they have in shaving weight off every bolt but not in this easy weight loss area.
DEANSFASTWAY
1,192
Hey Marcus ever work on any scooters like vinos lambrettas cagiva apirilias ? I know its pretty popular in your country . I just tricked out a little Yamaha Vino now it hits 55 with my big ass aboard , next is a Apirilia sr50 .the sr50 goes pretty good stock , There were somre real cool trick ones when I was in Georgia Apirilia school . I bet there are alot in UK ..
marcusgunby
6,450
Ive played with a no. of bikes over the years-had a trick big bore TS50 it had a autisa 72cc top end.It did 55 easlily till the big end stopped play.Done a scooter with a trick pipe and new weights in the auto clutch-that thing took off real fast-makes me want a revloc type clutch on my 125.
marcusgunby
6,450
BTW changing the subject slightly -i saw a 2003 Cr250 discounted at £3450 -any idea on why the 02 Cr is already selling for low money?a 125 cannot be bought here till end of Oct and it wont be much cheaper than that 250price?
bclapham
4,340
CRF450....enough said :flame:
i only did 5 laps on one last week and i want one now! But the 01YZ will be around for a while yet!
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
