General question here. I have a 2002 400exc, Big Gun pipe, power now with clean filters and clear breather hoses. I have noticed a few times when after about an hour of tight riding, it "sometimes" wants to run a bit rough and cut out when you first crack the throttle. If you turn it up through the rpm's, it runs fine, just not right off throttle. Sometimes it comes, sometimes it goes. I thought maybe the motor was getting hot but even if I hit a somewhat open area and let the motor get some air, it still may be doing it. My guess is that the valves are a bit tight and it only happens in certain riding conditions. Normally, you can smash the gas off idle and it throws you off and never misses a beat. I have probably put 500 miles on the bike and have never had the valves adjusted which is why I think this may be the problem but any suggestions would be appreciated.
