skirider
17
Really new to MX bikes and had a chance to ride the RM I bought a couple of weeks ago.
I am thrilled with the bike when it is "in the pipe" as the friggin thing screams (to me at least), what I am dissappointed in is the bottom end grunt...or lack thereof to be specific.
It may just be the bike's design and if so just tell me, but if there is a way to increase the low end performance I would appreciate hearing how. The bike is basically stock except for the DG pipe (head may have some work but I have no idea at this point). On my property I don't have that many areas where I can be in the pipe rpm range and to be honest I like to putt around a bit.....help me if you can.
Appreciate the input!
Chili
Apr 9, 2002
8,062
17
Modern 125's hardly have any bottom end, 22 year old Suzuki 125's have absolutely no bottom end. You could go up a few teeth on the rear sprocket and it would help a little but it's the nature of that beast unfortunately.
skirider
17
Chili,
Are rear sprockets with more teeth available for these bikes?
I have not idea what tooth count in on it now other than it is a Renthal brand.
Chili
Apr 9, 2002
8,062
17
Dunno what stock was for that year, my 86 was 12/51 my son's 03 is 12/49. I would try going up 2 teeth on the rear from what is currently on there and taking it from there. Cheap sprockets for now until you find the gearing you like.
angst2
36
the even cheaper solution is to drop 1 tooth on the front sprocket. Many stock 125 gearings have a 13 tooth front sprocket. Count the teeth on the front and if it is 13 you can replace it with a 12 tooth for about $13. This will do the same thing as increasing several teeth on the back. A rear sprocket would run you about $30 or more.
Eric Z
skirider
17
I will check the tooth count on both sprockets and see what I come up with.
Any recommendations for cheap rear sprockets?
Thanks again.
skirider
17
As you thought Chili the bike has a 12/51 setup right now. I will have to look around for a rear with a higher tooth count.
Any ideas on inexpensive ones to test with?
gwcrim
1,881
Try Rockymountainatv.com. They have their own brand of Primary Drive sprockets that are reasonably priced.
I grew up riding a '76 CR125 in the woods. I was soooo happy to have a powerful MX bike that the peaky powerband didn't bother me once I got used to it. The suspension sure did suck!
skirider
17
Tried rockymountainatv.com and no dice as the largest rear sprocket listed for an RM125 is 51 tooth....
Does anybody know if anyone makes a rear sprocket for this application that is larger than 51tooth?
