crxracer11
8
Hey all, sometime ago i posted that i needed help with a problem on my 1982 yz 490,i could get it to start and idle,but it would take any throttle,it was looking bleak,well i was able to set some time aside to work on it again,went thru the carb and everything one more time,i figured i would go ahead and change the flywheel,(being that the bottom end i purchased off of e bay was from a different year bike but identical to the 82),so i just swapped the magneto from the old to the new,using the new flywheel with the old didn't work,put the old one on and it fired rite up on the second kick, all this time,they look exactly the same,different numbers thou.i figured i would post this in case someone else was having this sort of problem,this bike is running great,(as well as an 82 could anyway) :bang:
