Hey guys, first post. I bought a YZ 125 as a project, previous owner says that it was running last summer. The engine is solid, body is pretty good. I think it had a recent top end rebuild, you can see the stampings on the piston if you look through the top of the cylinder.
My friend and I have been attempting to start it, with little luck. When we first picked it up, the compression was really low. I installed a gasket on the exhaust, and that helped. Installed a new spark plug (B9EG) as well. We get a spark, so it's not that. Took the carb apart and ran carb cleaner through it, it was pretty clean anyway. It was missing the airbox, so I've been collecting the parts for it.
Managed to get it to cough twice on us, but won't start. Mind you, it's still cold outside, so that may be a factor. However, we noticed that the throttle screw is missing. Could this be a factor in why in won't start? We even tried injecting a little bit of fuel mix into the cylinder, no luck.
Any help is appreciated.
~Josh
~Josh
