fordfather
5
Im new to dirt bikes bought 91 RM250 rode a couple times.I weigh 210 lbs.
-rear suspension was sitting way low
-front end feels real soft compared to friends 01 cr250
-wheel bearings dont spin freely
How do fix these problems
I want to make this a solid bike to learn on. I have the bike all apart what other shoul i replace or check?
help a rookie start ridin thanks :aj:
Trailryder42
295
If the wheel bearings don't turn freely, then you're probably going to need to replace them. About $15 for the rear and $8 for the front.
You need to set the suspension sag for your weight. Then adjust compression and rebound clickers to get the ride and handling you want. Lots of tutorials on how to do this around, just use the search function here. May even need different rate springs for your weight.
Remove/check the swingarm bolt and grease it.
If you ever decide you'd like to replace the stock pipe, let me know, as I have a new, never installed FMF Fatty nickle plated pipe to fit your bike that I'll let go for $60 + shipping.
FRESH VIDEO
