zio
Mr. Atlas
- Jul 28, 2000
- 2,284
- 0
I have a 2wd, automatic Tacoma and every time I go over a large bump, or g-out I can hear a very loud squeak coming from the rear suspension (leaf springs). Is this anything I should worry about? I did a brief visual inspection when it started happening (about 5 months ago), and didn't see anything loose, damaged, etc.
Also, my idle speed seems quite low (around 600 rpm indicated on the tach). The sucker vibrates quite a bit at this engine speed. I only need to bump it up a hundred rpm or so for it to go away. How is this done on my truck w/ EFI?
