In 99 my friend and I each purchased 99 KX 125. Since the bike is such a dog, we both decided to get the big bore kits. I decided to use Eric and my friend went with Rick Peterson. When I first received my cylinder back from Eric, I didn't really notice any changes except for the larger bore. My friend’s cylinder was different. RPM turned down the cylinder base and also had a different cut in the head. He also used a two ring piston in his bike. Once we both had a chance to break the motors in, it was time to switch. My friend and I are very similar riders (5'7" ht., 160lbs) with identical riding styles. Both bikes were faster than stock, but had different power. The RPM motor had low and mid power not much better than stock. The top seemed good but had a tendency to over rev. Eric Gorr's motor had more power everywhere. It pulled from bottom to top. It was definitely a noticeable difference. It was a much more useable motor. Even a novice rider could figure this one out. Can anyone explain why this is? What was RPM trying to accomplish by cutting the base down and changing the squish band so dramatically?
Another point I would like to make is the turnaround time and price difference? RPM was twice as much and twice as long. Need I say more?
Eric,
I appreciate the time you take in actually R&D bikes to maximize Hp, instead of just punching out a big bore to create more ponies.
I am considering a 02 YZ 125 (instead of the 02 KX) for next season. I plan on the Eric Gorr 144cc for the bike. Is the YZ 144 better than KX 144? If so, by how much? What is the hp difference between the bikes?
Also as an added note, my friend purchased the 167cc kit from RPM for his 01 KX 125. He didn't learn much from his prior mistake. The bike seems faster than my 01 KX 144 Eric Gorr motor, but only very slight. The $1600 price tag doesn't seem justifiable. He wasn't very happy with the result and now plans on selling the bike to switch to a YZ or KTM. If I purchased the bike (since it has minimal use on it) is there anything I could do to make this engine more useable? It just doesn't seem like the larger displacement is being maximized in terms of power. Is it a porting/timing problem? Why doesn't this bike rip? I can tell you from experience that a 01' RPM 139cc YZ is faster than an 01' RPM 167cc KX. That's a difference of 28cc. It just doesn't make sense. Also, the 167cc seems like too much motor for the 125 crank. The price is right to purchase this bike, but I need to make it run at its max. level. Will porting or anything make a difference? Or should I just scrap the whole idea and purchase a 02 yz 125 and add the Eric Gorr 144cc kit? I would really appreciate some sound advice and input.
Eric,
