kawasock me
- Dec 21, 2001
- 39
- 0
Hopefully, someone can answer this question for me. There are two rubber O-rings that go onto the output shaft of the transmission for my KX250. The aluminum sleeve closest to the shaft in the 2nd picture goes inside that gear that looks kinda cockeyed. It has a groove under the lip that looks like it would hold the Oring. After you put transmission assembly in the gear case you then slide that smaller spacer onto it, so it can seal against the oil seal in the case.
My problem, however, is that I'm not sure where the two Orings should go. My service manual hasn't arrived yet, and I'm not sure if it would even tell me where to put them.
Anyone know for sure from past experience?
