Spike024
4
Ok, I just got some new msr boots and i can't shift or brake as well now. I kinda got the hang of shifting again, after I adjuted the lever and made it higher, but its still hard for me to use the rear brake with boots on. Is there a way to adjust the brake also, so that it starts to slow down when the pedal is at a higher angle, and doesn't have to be pushed as far downward towards the ground, i mean i know there is a certain distance it has to travell, but can i make the distance higher up?
minifig-phil
Spammer
Apr 6, 2002
163
There is a screw that you can adjust to let the brake pedal top out to raise or lower the pedal hight. and to make it travel less adjust the rod at the drum with the wing nut. Just make sure you don't adjust it too much that the brake is always on.
