I'm on half of rebuilding a Husky 4 stroke engine which I have fitted a 100mm piston.The head gasket supplied was aluminium.Any advise on torque setting, should it be more or less than the standard steel issue??
Should the head be retorqued after 1st run of engine?
I figure as Aluminium has a modulus of elasticity 1/3 of steel the torqued figure would be less than the standard 37Nm + 90 Degrees any usefull advise appreciated.
