I need a new number plate/headlight shell and I was wondering if the green colors match ok. I saw that FRP has a UFO one. Any body had experience with that?
The aftermarket headlights strap on with rubber straps, and are usually too long for the stock forks..... As you know the original one bolts on and has rubber isolators.
Great Timing! Just Received my UFO headlight Assy last night & strapped it on. Color match is perfect. The straps have two holes for tension & with the stock forks its tight on the first hole so I can tighten it later if required. Looks to be a decent unit for a cheap price.
I like UFO and Acerbis a lot. Personally, I hate Maier. The plastic I have ordered from them was always a lighter color and flat in appearance. Also, the holes were as much as 1-2" off. I have never had a problem with UFO or Acerbis and the color match was always excellent.
