RTL
328
Rev pipe, Turbine Core II silencer. No problems with mounting, but I did have to call and have them send me the mounting hardware after I purchased the goods, they 'forgot' to include the mounting hardware.
KelvinKDX
1,622
RTL - The black Boyesen Ignition cover. Is that just a cover or do you really have Boyesen Ignition? If so - why did you get it?
RTL
328
KelvinKDX,
I searched out someone who made an alum ignition cover. I have had bad luck with the stock plastic units in the past in my MX days. I simply wanted a cover that was sturdy, I do not have a works ignition system.
RTL
328
The front plate on Page 2 is a UFO 2001 KX125 plate. I used a dremel tool to cut off the fork leg covers. I used a sanding bit which actually melted the plastic as is sanded away the plastic which left a near perfect edge.. I cut out a small slot for the top clamp to fit through. The bottom is held on by the two triple clamp screws. :thumb:
