I had a problem this weekend where my bike would suddenly start running like I was holding the throttle wide open. When it would happen, it was always after I had just got on the gas. When I released the throttle, the bike would continue to run like it was wide open.
The first time it happened, I pulled in the clutch and killed the engine. After that, when I started the bike on the side of the track, it would immediately run like I was holding the throttle open so I had to shut it down. I don't think the throttle was actually still turned - but the bike acted like it was. Is it possible that the throttle returned to closed but the slide stuck open?
After pushing the bike back to the pits, I started it and it acted normal. Took it back out on the track and ½ a lap later it happened again.
I wonder why the bike was stuck in the wide-open state once the problem occurred – but then went away after 10 minutes. Could heat have something to do with it and the problem went away after it cooled?
I took out the slide and it had some milky/greasy stuff on it. I don’t know what it was but it was fairly thick and possibly could have caused the slide to stick. I thought maybe some Belray grease from the lip of the air filter may have been sucked in. I cleaned the slide, drained the gas and mixed up some fresh.
Then I went to a grassy field and got on the throttle several times and had no problem. Took it out on the track and ½ lap later same problem. The only difference between the field and the track is that in the field I would open the throttle and hold it open as I crossed the field, then I would shut it down, turn around and do it again. On the track, I was on and off the throttle much more sporadically.
Here’s a history of what’s happened recently with the bike.
4 weeks ago I put in a new top-end and repacked the silencer. I had one easy ride and one hard ride since then with no problems. Between that last ride and this one, I removed the forks and greased the steering stem bearings. I also retorqued the cylinder and head nuts and cleaned the air filter. I found one cylinder nut loose and tighten it.
After riding I always drain the gas and store it in a metal can. There’s always a bit left in the tank that I can’t get without removing the tank. I’m running VP Racing Ultimate 2 (oxygenated).
The throttle cable may have been under some stress while I was installing the forks because the bar fell from where I had it perched and it was hanging by the cables for a few minutes. I removed the throttle cable from it’s sheath and inspected it. I didn’t see any kinks.
I’m going to clean the carb and throttle and replace the cable. I’m not optimistic that this will fix the problem. It’s very scary to test ride this beast now.
Any suggestions as to what could be causing this? I want to attack the problem from all possible fronts.
My present plan is to address the throttle, cable, and carb. I was wondering if an air leak could exhibit this behavior - only having an affect once the bike gets hot?
Thanks for all your suggestions!
