MONKEYMOUSE
- May 10, 2001
- 887
- 0
Some of you may remember my bike and everything I've done to it and the problem that I had/have. My 82 YZ100 has many new parts. I have well over $400 in parts on it that have never been ridden. Brand new clutch; basket, plates, pressure plate, bearings, throw out rod everything. Fresh top not even broken in with a new connecting rod and big end bearing. Front and rear hubs were fully rebuild with new axles, bearings, breaks and wheels were trued. Bike was pulled apart and put back together with at min 50% new fasaners. New swing arm bearings in all the linkage. As well as an entire brand new carb, fully jetted and set to factory specs. All has never been ridden on and only maybe maybe 10 min of run time in total on it all. It for some reason revvs out to no end when it starts. Did a leak down test and all was well I'm at a loss. pulled the cilly and head and put new gaskets and re torqued everything still just revvs out. I'm getting very sick and tired of having all that money sitting there that is well usless. My friend just got a really nice quad and I want to go ridding! The only thing I can think of are crank seals, there about the only thing that could be causing an air leak to make it revv out, as those are about the only thing I haven't replaced. How hard would it be to do new crank seals? Although why would it pass the leak down test (granted I didn't do the test my friends father did well I wasn't present but he knows his stuff).
