just did a top end my 99 yz250, weisco piston, cometic gasket set, torqued to factory specs, and ran thru three heat cycles before riding the bike hard. after about half a tank of gas started smelling coolant, checked out the bike and noticed the base gasket pushed out below the exhaust manifold. are aftermarket gaskets cheap or could i have another problem, i even put a thin layer of yamabond on the base gasket like yamaha does. any thoughts would be appreciated.
