GhostofSilverider
- Nov 27, 2010
- 22
- 0
I have had this 91 KDX 250 for a few months and it keeps giving me problems. This time I needed to bleed the front brake which wasn't functioning very well, besides the fluid obviously needed to be changed. When I opened the master cylinder, the fluid had a coffee like color , and when I bled the caliper, hardly anything would come out, I emptied the master cylinder, cleaned the dirt at bottom and refilled with old unsealed fluid and after a while following the bleeding procedure I read about in a magazine, I managed to get a few ounces of dirty fluid out, while the "new" fluid moved into the system.
Then I must have done something wrong or something broke down , I depressed the lever with no fluid in the master cylinder. From then there was no longer any resistance when depressing the lever, it was like it was full of air. Little bubbles would come out every time I used the lever, same at the bottom. But I kept trying to get the air out by pressing th elever and no improvement whatsoever. I can't bleed the line anymore , when I use the lever , with the bleeding valve open hardly anything comes out .
What happened ? How do I get it to work properly ? It doesn't need to be like new but at least it has to stop the bike .
