matt-itude said:I think you mean he pulled the brake lever.
YZ165 said:So the piston is pushed out to far. Take the pads off, get yourself a c-clamp and a piece of flat metal. Put the metal where the pads were and clamp it down with the c-clamp. You should be able to see if it is cocked to one side. Start with the side that sticks out the farthest. Squeeze that side in first and then put the clamp in the middle of the piston and push it back in by turning the clamp. Good luck, YZ165
Chili said:Or just take a flat head screwdriver and gently pry the pads apart. Warning if your too aggressive you could damage the pads.
