New question ! :-) (..though Im not sure if this is the proper subforum)
I also have a Suzuki DR650-RSE '95 mod.. This model is like the known DR650, the big thumper, but it has a mini fering and it's kinda heavier (approx. 170 kg dry). I use it for everyday bike, for some small road trips and a bit of dirt-riding.
The "brake problem" started with the front brake brake system. It was veeery soft.. I coulndt even block the front wheel with three fingers pushing it hard at 10 mph. It started to become dangerous!
First move : steel brake lines.
Second move : change of brake fluids (DOT4) with Silkolene brake fluids (higher quality than older ones)
(Notice that the front disk is 300mm in diameter with metal (hard) brake pads.. both products of Braking. )
The problem : the front brake system is totally improved, with lots of stopping power (=endos!) and good feel BUT! when the weather is hot (quite often in Greek summer) the brake becomes TOO STIFF.. Otherways, (when its cold, or during the night) the brake is really soft. I think it's the fluids..
what do you think about it ? :-)
